Sterring Box Gaskets
53hudsonguy wrote:
The cover gasket you will have to make. The gaskets that go on the bottom plate are special. They are about 2 or 3 thousand thick and this is how you adjust the clearance for the bearings on the worm gear. Hudson put about 10 of these gaskets there for adjustments. I believe I have some of these gaskets so if you want, e-mail me at waltmordenti@aol.com. Walt.Does anyone out there sell the two gaskets for the stepdown steering box? I've checked different sites K-Gap etc. with no luck
Glenn0
