Need a 34 to 38 rear pig
Went to put a set of 3.50 gears in my 34 rear end and found out at one time someone had put a 39 to 47 pig in it. The ring gear on the 39 to 47 has 8 bolts and the 34 to 38 has 6. Also the thread is larger on the pinion shaft of 34 to 38. The rear pinion shaft on the 34 to 38 is 1.250 and 1.375 on the 38 to 47. Need one soon, in Traverse City, MI until Sunday then be back to Richmond, IN Monday.
Let me know if anyone has one, the closer to erthier place or on the wat home the better.
Glen
Glen
Glen wrote:Went to put a set of 3.50 gears in my 34 rear end and found out at one time someone had put a 39 to 47 pig in it. The ring gear on the 39 to 47 has 8 bolts and the 34 to 38 has 6. Also the thread is larger on the pinion shaft of 34 to 38. The rear pinion shaft on the 34 to 38 is 1.250 and 1.375 on the 38 to 47. Need one soon, in Traverse City, MI until Sunday then be back to Richmond, IN Monday.
Glen
GLEN, I have a complete rear end I took out of my 37 "T" located at Salem Indiana, Send me an Email or call. 812-883-6365--- BUD0 -
Thanks Bud, be there next week0
