On cylinder head-what goes here?
On a 308 engine, visualize the driver side of the cylinder head. Counting from front to rear, next to the 3rd and 6th cylinder head bolt there is a notch. Under the 3rd bolt there is an oval shaped piece with the ends bent at a right angle. One end fits into the notch. The other end hangs over the edge of the head and has a hole in it like maybe it is for a return spring or something. The 6th bolt does not have this piece but there is a notch as previously mentioned. What is this for? ? ? ?
Yes maybe I am being anal but I still want to know if the engine is missing something.
Doug
Doug
My Hornet has the same, and there is nothing there, but on the Jet, in the same position, there is a sheet metal clip under the head bolt, with a bent over ear which fits in the notch, and the outer end of this piece is a holder for the ignition coil wire.
Geoff.0 -
dougc_portland wrote:On a 308 engine, visualize the driver side of the cylinder head. Counting from front to rear, next to the 3rd and 6th cylinder head bolt there is a notch. Under the 3rd bolt there is an oval shaped piece with the ends bent at a right angle. One end fits into the notch. The other end hangs over the edge of the head and has a hole in it like maybe it is for a return spring or something. The 6th bolt does not have this piece but there is a notch as previously mentioned. What is this for? ? ? ?
Doug
Doug, Your hunch is correct. The oval shaped piece is for a return spring from a 2bbl carb(WGD). The notches cast into the head are for a twin H setup. They were used in the twin H accelerator linkage. No, you're not missing anything.0
