Air bag issues - Please help
Hello all, I'm new to this forum and have a couple newB questions regarding airbags. I have never had them on a vehicle before and got a car a bit ago that has them. So, the issue i'm having is that when I try to raise or lower the rear of the car it does nothing but click once....I flip the switch up or down and a single click every time I hit the switch sounds. It seems to me its coming from underneath the car just behind the drivers side door. Has anyone had this problem? Could it be a fuse, switch issue? I have zero knowledge when it comes to bags....
The front work just fine.
Thanks for the help!
ocsnakeremoval@yahoo.com
Hi Jason,
This sounds like you'll just have to roll up your sleeves and start investigating. Sounds like you have solenoid valves since they are not located under the dash. I'd start by just making sure all the electical and plumbing connections look exactly like the fronts since they're working. This will probably reveal something, then go from there!!! Good luck - let us know how it goes!
Lee0
- 101 Essex Super 6
- 612 Vehicles
