Heater Control Cable
Jim Kilday
Where might I find a heater control cable for my '46 Coupe? I would like a NOS part if possible?
Thanks
Thanks
Jim, this is very easily resolved. Go to the auto supply and buy a universal hood cale. Check to make sure it is the desired diameter, about $10.00. Cut off the length you need, push a piece of correct diameter rubber vacuum hose and/or heat shrink over it and then install. It is clamped at both ends. CG0
