Sensatrak shocks on a Hudson
Here are part numbers for Monro Sensatrak shocks that will fit Hudson step downs
You will have to make a lower mounting plate for front shocks and re bush the rears but the ride is phenominal improvement.
Front 37237
Rear 37162
I believe 2000-2004 Dodge Dakota. So vehicle weight is close to equivalent.
Front 37237
Rear 37162
I just put Monroe Sensatrac 5751 up front and Gas 31094 on the back of my 54 Sedan fit perfect.
How are these different?0 -
Anyone who has installed Sensatrak shock to replace OE will notice a difference in response in particular on rougher roads.
Sean here is a helpful link feel free to post all on your website too.http://www.monroe.com/products/sensatrac_default.asp?currItem=%5Flevel0%2EmcSensaTracHeader&currSubItem=&rolloverObj=%5Bobject+Object%5D. When I was researching stroke mounting types etc I found that the numbers given were a good match in regard to vehicle weight also. When I get to this on the 52 I will PM you mounting plate design quite simple to do.0 -
Great stuff Ray. Thanks for the info. Got the local dealer down the road so I will use these on the 54 Hollywood and see what the difference is like.0
