Pilot Bearing
Yes the bearing must be greased, I use wheel bearing grease.0
am replacing my clutch and ask doug wildrick and he said the fluid in the clutch will lub the bearing. grease my get on the corks and would not be good. doug said it is ok to put a little light oil before you put the disk and pressure plate on the flywheel0
