Source for Terraplane parts.
I got my rubber from K-GAP some time ago.
If you want to make your own harness, which I would suggest using heavier wire,
you can get good original looking wire from Rhode Island Wire. I would also
reccomend running a separate ground wire from the headlight connector all the way down to the frame. Depending on the overall diameter of the wire bundle
from the headlight you may have to bore out the hole in the mounting bolt. I did
this on mine and Ihave bright 6 volt lights even using the 50 CP bulbs.
Howard0 -
hello, if you are looking for recommendations based on personal experience i can only offer restoration specialties and supply for window channel. for wiring i have heard good things about rhode island wiring and also ynz yesterdays parts. they both list hudson/terraplane among the cars for which they have patterns. narragansett reproductions also shows hudson patterns available. good luck. regards, tom0
All your Terraplane window Channeling can be obtained from Vic Zamora in Ca @ 562 947 5864.. Great Service, good Product & quick shipping.0
