1930 Essex lubrication recommendations.
I found the operators manual online to this vehicle and it mentions different oils for lubricating various parts of the vehicle and need some info on how the names relate to modern oils/weights.
Engine oil: high grade medium heavy body. Maybe 30wt?
Light motor oil for starter etc. Maybe 10wt?
Transmission oil?
Rear axle heavy body differential oil. Maybe 80wt?
Heavy body gear oil for steering gear?
Any help would be appreciated so I'll know what oils to get to start working on this vehicle. Thanks. Steve
Transmission oil?
Engine oil, 20W-40, such as Castrol GTX.
Transmission 90 weight
Rear Axle 140 grade
Steering box, Steam cylinder oil 600W
Starter, generator bearings, etc. engine oil in your oil can.0 -
Thanks Geoff. That is the information I was looking for. Much appreciated.0
