55 Fuel Pump
ski4life65
The fuel pump on my 55 308 went south. I have a spare for my 51 308 on the shelf. Will it fit? I thought it would work, but when I took the pump off of the 55, the arm was a little different. It has a curved piece that fits on the lobe and slides back and forth on the arm. Is this specific to hash 308's, or will my earlier pump work fine?
Don
Don
I don't know what the differences are, but the numbers are:
Carter M729SA - 1948-1954
AC (Fuel & Vacuum)
583 - 1948-1952; 1953 early
4057 - 1953 later; 1954
Carter M729SB - 1942-54 all; 1955-1956 Wasp
Fuel/Vacuum Pump
Carter - M2033S - 1955-56 Hornet 6
Carter - M2256S - 1955-56 Hornet V-8
AC - 4250 - 1955-56 Wasp, Hornet 6
AC - 4293 - 1955-56 Hornet V-8
Alex Burr
Memphis, TN
hetclub.org/burr0 -
ski4life65 wrote:The fuel pump on my 55 308 went south. I have a spare for my 51 308 on the shelf. Will it fit? I thought it would work, but when I took the pump off of the 55, the arm was a little different. It has a curved piece that fits on the lobe and slides back and forth on the arm. Is this specific to hash 308's, or will my earlier pump work fine?
Don
I don't know if this helps you at all, but I do have a mechanical fuel pump from a 352 Packard v8....from my 56 hudson0 -
I went ahead and put the earlier pump on the 55 308. It's pumping fuel and the engine is running. Hopefully it doesn't cause any damage. If anyone has a definitive answer, let me know.
Don0 -
ski4life65 wrote:
The arm with the sliding action is no different than the the 48 to 54 pumps. Just make sure you install the gasket pack between pump and block. They used that one to make the engine quieter. Walt.I went ahead and put the earlier pump on the 55 308. It's pumping fuel and the engine is running. Hopefully it doesn't cause any damage. If anyone has a definitive answer, let me know.
Don0 -
Thanks Walt. That's what I thought, but just wanted to make sure.0
