'38 112 Convertible Project Pictures
Looking good, Dave!
Keep up the good work (and the pictures)!
Like that you can see the VIN in the front axle.
Kevin C.0 -
Shocking!!!!
Stuff is all looking good as the progress goes on. That looks a lot like the heater that is going into my 39... Well, then again, I guess it should.0
I still have the other heater Rick. Here is a picture of the rear cross member that also shows the VIN. Thanks for your comments guys. By the way; we started water sanding the fenders today. Should start the painting next week.0
I chalked the numbers, then sprayed them with clear coat. Some of the numbers are a little worn but everything matches except the 212 CI motor.0
Thanks for the comment Kevin. My mentor Junior is responsible for all the work on the heater, as he is on most of the other work. I pretty much just do what he directs me to do.0
dave kastelic wrote:Here is a picture of the finished heater for my car. Also included a few frame pictures with the wheels on.
Dave,
Do you have the defroster kit to use with the heater?
They occasionally appear on ebay.
Kevin C.
P.S. Keep the pics coming!:D0 -
Yes, pulled it out of the parts car.0
