Idling funny
Aaron D. IL
I got my 262 going with carter WGD carb... set the timing and the idle. The car should be idling a bit lower (the book says only like 500-600 rpms) maybe but anyways what it's doing when running is ocillating.... the idle speeds up, slows down, speeds up, slows down. When I play with the idle adjustment a bit lower she dies.
Suggestions ?
Idle screws are backed out 1 and 1/2 turns as per the books' instructions. It does accelerate smoothly now that I set the timing.
More clues: disconnected the vac advance and no change. Metering rods seem to be moving up and down with the occilation so I have to assume it's somewhere in the carb.
Suggestions ?
The 1 to 1-1/2 turns of the idle screws is just a guide to get the starting position. You have to adjust these in or out to get a smoothe idle.0
Aaron D. IL wrote:
The float level is to low, that will cause the idle to float. WaltI got my 262 going with carter WGD carb... set the timing and the idle. The car should be idling a bit lower (the book says only like 500-600 rpms) maybe but anyways what it's doing when running is ocillating.... the idle speeds up, slows down, speeds up, slows down. When I play with the idle adjustment a bit lower she dies.
Suggestions ?
More clues: disconnected the vac advance and no change. Metering rods seem to be moving up and down with the occilation so I have to assume it's somewhere in the carb.0
