Back Up Lights
I have back up lights on my WASP, but no switch to activate them....Does anyone have a switch? If not I'm sure I can pick up an easy CONTACT on off switch but the challenge then becomes how and where to mount is so that it only activates when the car is in reverse..
Any thoughts or recommendations???
On my 51 hydromatic there is a switch on the cowl or steering column that is activated by the shift linkage. I wired it in anticipation of adding lights... must be std equipment. Will check out in AM. W0
