looking for a used stepdown u-joint
Hey Dougson,
Just pulled the rear out of mine. Not sure if all the u-joints are the same or not, but you can have the caps with the bearings in them off of my back u-joint if they'll help!! PM me your address and I'll mail them to you.
Lee0 -
What?
I would suggest that you bite the bullet, go to napa and just buy a new joint for $10-$15. I don't think mixing needle bearings sounds like a good idea. I would think that putting it together once, and correct is the preferred way. I think although remote, you are just introducing an opportunity of failure to the ujoint, maybe not right away, but likely down the road. Best of luck to you.0
