Lifters for Jet
Unknown
edited November -1 in HUDSON
Can you still get lifters for a Jet?? Mine are getting noisy and I have tried too adjust them but it hasn't helped much.:oops:
Thanks, Barry Smedley
53' Super Jet
and a bunch of Crosley's
  • Check with Uncommon Engineering at www.uncommonengineering.com or Dale Cooper ay www.hudsonmotorcarco.com Walt.
  • Geoff
    Geoff Senior Contributor
    The valve lifters are the only interchangeable parts between the bigger motors and the 202 Jet. Probably the head of the bolt is recessed, which is why you cannot adjust them to be quiet. The feeler gauge measures the unworn portion of the head. The valve stem pounds it's way into the bolt head. This can be refaced quite easily. The earlier splasher engines had a better design bolt in that there was a raised portion above the hexagon which was the same diameter as the valve stem.
