choke/manifold heat tubes
Here's what I used. The only thing different from the original is that the ends of the insulation are covered with a black coating to keep from fraying, and Hudson used a hog ring to hold the insulation onto the choke tube which limited the fraying. They come in a standard length of which one is a 1/2" too short for the front choke tube on Twin H. I just put the short side up at the carb and you cant see it because of the air cleaner.
http://www.lategreatchevy.com/chevy-choke-heat-riser-tube-insulation-1958-1964.html
Hope that helps!
John Forkner0 -
Thanks John. Mine are original and they are getting brittle. I did the same with the ends by the carbs, but now they are about a inch short. I ordered a pair from Ecklers.0
- 611 Vehicles
