Hydramatic fluid?
Castrol Dexron 111 Mercon is the fluid you want. Hudson hydra-matics, with converter drained holes 11 quarts. Put 5 in, start engine, and slowly add the rest. Do not add any junk to your trans, trouble later. Walt.0
dextron 3 is what I put in my 52 hornet , you will need about 11 QTS PLUS if trans is dry0
Thank you so much. I'll drain it and refill:cheer:0
