12 volt bulb number needed
Chris Smith
I am assembling the steering column on my 54 Hornet after rechroming. I need the 12 volt bulb number to replace the FS51 6 volt bulb that lights up the hydramatic shift selector pointer.
thanks
Chris
thanks
Chris
Chris,
When I converted my 54 Hornet to 12 V last summer I used #57 lamps for the Hydramatic shift selector and all dash lights, including the oil and gen lights.
Hope this helps,
Tom0 -
That helps, thanks. I also wonder if anyone is reproducing the steering column seals at the floor pan. One is a molded rubber and the other is just a flat piece that is fabric reinforced rubber.0
Hey Chris, 12 volt bulbs to replace 6 volt ones are as follows; 53 for51, 57 for 55, and 67 for 63. Give me a call if you need other ones. Steve.0
thanks Steve0
12 Volt Bulbs (1951 Hornet)
Not sure all are used in the '54s. Walt-LA
use number bulb designation
Courtesy lamps (doors) 4 1073
Tail/brake 2 2057
Park/turn (front) 2 2057
Turn (rear) 2 1056
Tag 2 67
Grille (emblem) 1 57
Dome 1 1073
Dash lights 3 57
Gen/Oil lights 2 57
High beam 1 57
Radio 2 1893
Hydromatic (NDLR) 1 53
Quarter lights 2 89
Flasher 1 NAPA 7319
Headlights 2 -
Trunk 1 10730
- 117 Hudson 1916 - 1929
- 22 Upcoming Events
- 98 Essex Super 6
- 582 "How To" - Skills, mechanical and other wise
