oil filter & ignition
rodder wrote:Is there a way to put a full flow oil filter on a 308" Hudson engine? Also, is there a modern 12v ignition that can be adapted to my 308?
Rodder: Do a search for keywords like: "oil filter" and "ignition" . I know I've seen info before in previous threads.
Also, check out the Street Rod Forum at the top of the main Hudson page. There was a thread today about the oil filter for the straight 6.
Russell0 -
Sorry, that was you that did the posting. Did you notice TwinH responded to your query?
I'm thinking this dual-forum is suckin'!! Wish we could all just get along!
Russell0 -
Rodder, We have the 6 volt positive ground and 12 volt negative ground conversion using the hudson distributor.
Randy Maas
maasfh@ntslink.net
309-968-61570
