37 engine parts question - ID
I am starting to put the 37 Terraplane 6 together and need to find out about these two parts--
Does the left metal spacer go behind the crank dampner? This engine had some washers when I tore it down. Does the right one go over the cam and spaces the cam out from the block? Where do the ears go direction wise? this one did not have a spacer or thrust washer ---
You're right on both parts. I don't remember which way the ears point on the cam spacer but it seems like it will be self evident when you go to install it.0
