brake pedal free play
Edwardjohnsr
I recently adjusted the linkage of the "double safe brake system" on my Hornet. Ever since, the brake pedal doesn't come back up all the way. I have to pull it back for the last 2 inches when I use the brakes. Since I have one of those mechanical brake light switches (instead of using the usual hydraulic switch) the brake lights stay on until I pull it back.
Does anyone have a suggestion on how to correct this?
Ed
Ed
Most cars had a spring from the back inner master cylinder (L shape bracket) to an "eye" clip on the linkage. May need to install one0
You are missing the return spring that pulls the pedal back, check # 17, it's the spring that does this job, from pedal rod to a clip that is tack welded to the under side of floor board. Picture enclosed, Walt.
Thanks Walt. That must be it.
Ed0
