'37 TP brougham parts needed
I have a '37 Brougham, model 71. I'm needing the metal pieces that go around the doors that the windlace attaches to, and the piece around the rear window that the headliner attaches to. Also needed are the pieces that go BEHIND the window surround trim on all four windows, as well as any attachment screws. Also needed are good patterns for the door upholstery and the rear seat area below the windows, both sides. Also needed is a complete right door regulator assembly with all attachment hardware. Does anyone have a good pattern that I can use to cut a spare tire cover in the trunk? Also need a windshield wiper motor.
Whatcha got???
Whatcha got???
If you're speaking of the plywood 'shelf' in the trunk, talk to Robbie Williams. The motor is SK-25, if that helps. You also need small clips held together by a spring, to hold the wiper linkage arms to the studs on the motor's drive bracket, but these are common to many cars.0
Robbie sent me a paper pattern to cut a tire cover for, but I've lost it.0
