TIMING GEARS
I have three new old stock fiber timing gears for sale.
The package is marked 41-51 six & eight cyl.
These match up to the used eight cyl. one in the photo.
Believe they are 20 degree?
Price is $15.00 each plus shipping
The used Hudson gear is $10.00 plus ship.
Email tunentime@ hotmail.com
Thanks Roy
Old Fogey, I think your gear has a different pitch
on the teeth angle.This box is marked 20 degree
but as you can see its not printed on.
Somebody with more knowledge on this might help us out.
Thanks Roy0 -
Early timing gears had a 14.5° pressure angle, the later ones had a 20° pressure angle, I'm not sure what year the change over occurred.
Disregarding the technicalities of what the pressure angle is, importantly, it does subtly vary the shape of the gear teeth. This means that if you do mix them up, ie a 14.5° crank gear with a 20° cam gear or vice versa, you will get premature gear wear and failure.0 -
If you can tell me the thicness of the fibre gear and the number stamped on the steel gear I can tell you what you have.
The early gears were thinner than the later 20 deg gears.All in all I think there were three thickness gears used over the years.0 -
Old Fogey UK wrote:
Is there a way of checking the angle of the gears ?
Not readily. It is possible but specialist gear measuring equipment is necessary.
I do have an early NOS 14.5° fibre timing gear if you get desperate.
Some info on how pressure angle changes gear tooth shape.
http://shopswarf.orconhosting.net.nz/spur.html0
