Door Panels
you have to push in hard on the escutheon plate & between it & the handle itself you will see the handle's shaft with a small pin holding the pin to the door mechanism. I've usually found using a nail, which is about the correct diameter, will push it through BUT you'll probably have to use a hammer to do so. Sometimes this operation, since it's usually hard to push the escutheon in far enough & at the same time try to drive the pin out, requires 2 people.0
