Radiator pressure
As far as I remember, the '48 & '49 did not use a pressure radiator cap
Jerry0 -
If you want a pressure cap on the system, I'd keep it to 4lbs max up to 1947 models and 7lbs thru the 54 models. Hashes with A/c would probably require a 12 to 14 lb cap. Just my 2 cents worth.0
