35 ford Horns
essexcoupe3131
how close are the 35 Ford Horns in comparison to the Terraplane 1s
as you can get in 6 and 12 volt and the 35 look so cool
way better than the ooogha style
thoughts
thoughts
They are very close, the only difference is in the dome top, I suppose you are talking about the ones attached to the headlamps.0
Hi Mike
I've got a couple of those you could look at if you are in Wellington or are coming to Wanganui for the Internat Rally in mid Jan.. Will 6 volts be a problem?? No Fraud script on them!!!
Dave0 -
hi Dave don't think I will make either unfortunately
would I be able to put a relay in to convert them?
email me
Thanks
Mike0 -
essexcoupe3131 wrote:hi Dave don't think I will make either unfortunately
email me
Thanks
Mike
You should put in a horn relay anyhow, but you will still need to drop the voltage to 6 volts.0 -
Hi Dave, i used the wrong words, have a relay already
i meant to put can i put in something to drop the power to 6 volt?
Mike0 -
I understand you can drop the voltage but you'll need advice from someone more knowledgeable in these matters than I am. An old time auto electrician or possibly Geoff Clark would be a good start or there are several posters on this forum who seem to be knowledgeable in this area.0
spoke to my auto electrician, said no worries he could sort it
if anything recons will make the horns louder
Mike0 -
A funny story..
Many years ago, My father wanted to use a 6 volt Model A Ford Ahoogah horn on a 12 volt car. He asked his neighbor, who was an elecrical engineer, what to do?,,
He told him to use a 6 volt tail lamp bulb in series with the horn. Of course every time he pushed the horn button, the bulb blew out! He called me and asked for advice. I told him to try a headlight bulb! It worked, but with a slight delay.. LOL.. In fact, a simple tightening of the adjuster slowed the motor down enough to work just fine..
