wanted- cast exhaust piece below manifold
hoggyrubber
i am interested in getting one for my 52 308, mine is broken. the old one came loose without breaking a stud, the inner mounting stud at bottom has been broke fore a while looks like. the other one broke moving the engine around. thinking about making one of steel but thought i might buy one if someone has one for sale. thanks, stacy k
Stacy, check your PM0
I think I have one available too if Hudzilla cant help.0
Me too. probably 5 of those on the shelf . . .0
thank you all. i pulled to trigger on hudzilla's offer so i am good. thanks for all the help. i am getting close to driving the hornet again with the 308! last weekend i got the engine in and everything hooked up. now that that is done and the entire frontend rebuild it's starting to look like a real car. still have a few loose ends to tie up but soon, very soon.0
hoggyrubber wrote:thank you all. i pulled to trigger on hudzilla's offer so i am good. thanks for all the help. i am getting close to driving the hornet again with the 308! last weekend i got the engine in and everything hooked up. now that that is done and the entire frontend rebuild it's starting to look like a real car. still have a few loose ends to tie up but soon, very soon.
That's great! Keep up the good work.:cheer:0 -
glad to hear you got the engine back together.0
i have had it together for a while, don't know how it will run yet. :whistle: i have been going thru the frontend- kingpins, bearings, shocks, all that stuff lately. i decided to run new brake lines because the last ones i did didn't look neat enough. it was pretty nice to get the engine and driveline in. got the front brakes adjusted according to major brake adjustment in manual and i an happy with that. if it runs decent i may tear into the electrical next. i am tossing the idea of buying a whole harness after reading the thread on it a ways back.0
I bet it will run fine. If you dont replace the original wiring right away at least install an inexpensive Shut off at the negative Battery terminal because of the old wiring frays over time.0
