Brake drum shield for 1952 Hornet
While adjusting the brakes on my 52 Hornet I noticed the shield aroung the outside diameter of the left rear brake drum was loose. After removeing the rear wheel the shield is loose enough I can slide it off the brake drum. Since it helps disipate heat from the drum I would like to fix it. I believe it was originally a press fit. Has anyone else had this problem and how was the fix accomplished?
i wonder if it could just be "staked" on in a couple of places with a prick punch?0
The shield is also a vibration dampener ,some makes used a coil spring for this . It is not a disaster if it is missing - lots of them are. Perhaps a slight "Tack" in a couple spots with a stick welder ? Just dont linger and make a hot spot.
Roger0 -
I decided to leave it off. Hange it on the wall as Hudson memoralbilia.0
That wont hurt a thing , most of them are gone by now anyway. They were thin and rusted off the drum easily over time. Most other car makers just put up with noise from the brakes,
Roger0
