FUEL PUMP 308 HUD
Airtex Fuel Pumps
-6737 - inlet towards front
-60167 - inlet towards rear
Same spacer as original pump.0 -
THANKS GRIM, CALLED AUTO PARTS AND THEY CAN HAVE IT TOMORROW A.M,0
51HudMan - When mounting a 6737 fuel pump on a 308 be sure the spacer gasket stack is at least .450" thick. I think this a little thicker than the spacer for the Hudson fuel pump. If the spacer is not thick enough the AMC pump will be damaged. I had a letter on this in the Sept/Oct 2010 WTN . Norm0 -
The AMC pump takes a 3/16 gasket, .450" thick can give you trouble going up a steep hill. Walt.0
