308 Head Gasket Help!!
I was going to install my freshly milled and epoxy red painted cylinder head tonight on my '54 308.........but NOOOO..... while checking the gasket alignment on the head and block, I noticed a group of coolant holes did not line up with the gasket. Actually, every OTHER trio of these holes DID line up, in a repeating pattern. I believe this is an old replacement style gasket, and I did not want to install it until I heard some opinions! So please...... has anyone seen this alignment problem? Of course, it does not go away if I flip the gasket. The gasket is secured properly in all four corners to show actual alignment... AND... I no longer have the original gasket to compare. Thanks for any help!
Scott
Scott
Are you sure you have a 308 head gasket? 262's from 48 to 1950 are narrow blocks and gasket will not line up on a 308. 51 up 232's and 262's are wide blocks like the 308 but gaskets will not work on the 308's. Get your gasket from Dale Cooper. Walt.0
What gasket do people use when using a 262 head on a 308? Wouldn't the gasket be the same if the heads interchange?0
Just order a correct new gasket from Dale Cooper and be done with it0
Okay, Thanks for your help!0
