Stepdown Hood Latch Mystery
SuperDave
SuperDave Senior Contributor
edited July 2012 in HUDSON
I have two different bottom hood latch assemblys on my 49's. My 49 Super 4 door has a small latch about 6 1/2" wide. My 49 Com. Conv and a Super 6 Two door have a large one 12" wide. I suspect my four door has a later model (50?) latch and apron. The 49 and 50 have different part numbers in the 48-54 master parts book. The pic on the left is the conv. and the same as the Super two door. The one on the right is the Super 4 door.
  • Dave, you are correct. Similar btie panel was used on the 1950 but the wide base was used on the 48-9 only. If the 1950 base is used with a 48-9 hood, it tends to not shut as low as with the correct base.
  • 54SuperWasp
    54SuperWasp Expert Adviser
    Hi Dave, I think I missed something here. I remember, not so long ago, that you were looking for a conv. Looks like you already found it. Have you posted pictures? If so, where so I can see it?.
    I'm glad you did. Michel
  • Park_W
    Park_W Senior Contributor
    Well, c'mon, Dave ... show 'em some pic's of that beautiful car! By the way ... you gonna' live with that top for a while, or replace it right away? I leaned on Herbert a number of times to get a nice tan top installed, but he wasn't too concerned over the one that's on it.
  • nick s
    nick s Senior Contributor
    Dave, in addition to what Hudzilla states, if you have a 50 hood installed, they can be made to work, you need to use the 50 crossmember and latch
  • SuperDave
    My hood fits fine and it'sa 49. ?? The panel that the latch mounts on must be 50 as well. Maybe someone made other alterations, but I never noticed anything, I have had the front end apart a few times.
