This weekend's project.
While driving around in my 37H8sd, I found hot air entering the floor area. When I removed the floor mat I found a large gap between floor plates at the base of the steering columne. Also there was a opening all around the transmission where it comes thru the floor. Some insulation tape filled the gaps, and I also glued alum foil to the insulation on the underside of the floor mat.
