1933 (32) Terraplane Convertible coupe (cabriolet) passenger side window frame needed!!
I am trying to locate the stainless steel passenger side window frame channel for my 33 terraplane. I have discovered that it is the same material as 33-34 Ford, even the fancy clip on the mitered corner, so the material has to be out there somewhere if I cannot find the actual window frame. I have the lower channel and regulator. Any help would be greatly appreciated!! Thanks, Ken
Found it! Where the car had been stored at previous owners, dug through building again and found....true needle in a hay stack happy ending!0
