'34-35 H /T Division bar rubber
StillOutThere
StillOutThere Expert Adviser
edited July 2012 in HUDSON
Am rechroming and reassembling the disappearing vent window assembly in my '34 Terraplane convertible. Installing the K-GAP /Metro rubber gasket around the vent window "C" shape. That leaves the vertical division bar which originally had a sort of "L" shaped rubber. Was it glued in? What has anyone else used to replace this original rubber? Source? Thanks!
  • Jon B
    Jon B Administrator
    edited July 2012
    Did Metro not include the 'h' gasket along with the "C" molded channel?
    When I worked with Metro (maybe 35 years ago) to reproduce the "C" molded channel for the convertibles I found a small company to extrude some of the "h" for me. I would have to rummage through boxes of stuff to see if I have any of these left....but right now I'm packing the Terraplane to leave for the National in the AM. Shoot me an e-mail if you don't find anything, and maybe I can find some of the h channel when I get home. HETdetailed@verizon.net (drop the HET before mailing).
    --Jon Battle
    PS - you might want to post this in the "Hudson" forum, it's presently in the "All Makes" forum.
  • StillOutThere
    If it is an H-shaped rubber then I wouldn't recognize it if I had it. The gaskets were bought decades ago and came with the car in the "misc. parts" box.
    Is there a way to change forum locations or do I just start from scratch reposting the original text?
    Thanks
