308 with O/D trans in 47 PU
Finding a steering column from a 2-lever car should give you all the parts you need for shift linckage. Not sure if the shaft would need to be shortened.
Roger0 -
If you use the step down column (SIC?),you will have to modify the linkage. I had to weld in some pieces to get it to work.I used some 1/8 " rod to make a pattern.0
