Paper sleeve for visor about Hydra-matics?
RL Chilton
edited September 2012 in HUDSON
It is my understanding that a new Hudson equipped with a Hydra-matic transmission in 1952 (perhaps '51, '53 & '54, as well) had a paper sleeve wrapped around the visor giving instructions as to the proper operation of the Hydra-Matic.
Does anyone have a photo, or an original sleeve of one of these? I'd like to make a reproduction, if possible.
  • StillOutThere
    StillOutThere Expert Adviser
    There was one with my '53 Super Wasp Brougham when I purchased the car at 20K miles. It would be the same visor sleeve of thin poster board stock (not paper) for all '52-54 Dual Range Hydro-equipped cars, but not the '51 single range Hydro. I think I still have it...... somewhere. Decent condition as I recall.
    I did a very similar project for the '57-58 Chrysler and DeSoto with pushbutton torqueflites. Printed the sleeves from a nearly mint original. Printer said it was quite a challenge though only red and black inks were used on that example.
  • I did have one on my 51 Hornet that I bought in 1959 with 14000 miles on it. Now maybe someone took one off of a 52 or newer. I will have to look and see. Like everything else I have accumulated it may take some time.
  • Club Coupe
    Club Coupe Expert Adviser
    I have a repoduction for a single range hydramatic that I bought from K-Gap about 10 years ago. I'd be glad to scan it and e-mail it or color copy and send it by mail.
  • RL Chilton
    Club Coupe-
    Was there one version for single range and another for dual range? I'd for sure want the dual range, but could use both, if I plan on making reproductions.
    I'll send you a pm.
  • EssexAdv
    EssexAdv Expert Adviser, Member
    Russ, there was at least 3. 1 for the single, 1 for the dual and one for the Borg warner. There is a guy on EBay who sells repros of the single (I think).
  • Was the Borg Warner good for a '50 Pacemaker?
    If so, I'd like to find a repro for mine.
  • SuperDave
    SuperDave Senior Contributor
    Nope! Borg warner transmissions were only used in a short run of 54's. 1950 did not have automatic transmissions. I bet there was a sunvisor jacket for the drive Master etc. The 1942 did ..
  • I thought that BW meant the O/D unit on my '50 Pacemaker.
  • MikeWA
    MikeWA Senior Contributor
    The Borg Warner automatic transmission was used for part of the '54 model run after the GM Hydramatic plant burned down, so there were no Hydramatics available for a time. Completely different than the Borg Warner overdrives, used in all OD Hudsons (and many other marques).
  • enrgsr
    enrgsr Expert Adviser
    I have an original sleeve that I bought from Red Burke, who has recently passed. It's yellow and black entitled, 'Know Your Hydramatic Drive' on one side and 'How to Operate Your Hydramatic Drive' on the reverse. I could make a copy and mail it to you. Let me know if this will help.
    Jerry
  • RL Chilton
    Jerry-
    I did have someone send me a copy of the front and back. I would like to see a picture of your original if possible, so that I know what the whole thing looks like.
    Russell
    HETrlchilton52@gmail.com (drop the HET)
  • enrgsr
    Russell--two pictures sent to your e-mail address. Hope you get them alright.
    Jerry
  • RL Chilton
    Jerry-
    I got it. Thanks so much!
  • cardoclassics
    cardoclassics Expert Adviser
    Information on sleeve-can be found on ebay, item # is 160575693542.........on Pinlady Store. hope this helps. Ron.
