Existing accessory voltage reducer?
Unknown
edited September 2012 in HUDSON
As some of you may know, I'm converting to 12 volts (sorry for so many questions and posts) and I am trying to find voltage reducers for the accessories and I was told this about my '52, "Your Hudson should have a instrument voltage regulator already. You might be able to use the regulator you have with 12 Volts, as all it is is a bimetal strip type voltage regulator that goes on and off and keeps the voltage somewhere around middle of battery voltage. If it does not work, then get the IVR from 56 and up Fords. That should work..It is a little metal box, about 1 1/2 x 3/4 inches. Has two wires."
... Can anyone confirm this, and under my dash looks like spaghetti, so any unnecessary rewiring would be great. Thanks
