anyone have any well used 53 front turn sig lenses for sale
hoggyrubber
i just finished repairing the pass side lens for my 53 hornet. i used some of that plastic epoxy. 2 of the mounting holes were completely broken off and i had a piece cracked off and missing. i filled in the missing piece and built up the mounting hole locations and drilled them back out. turned out pretty good for my ride.
i don't have a drivers side one i can even repair to make work. just wondering if anyone has a well used one for sale. even some cracks/breaks ok. i get a bigger kick out of fixing up something that might get tossed then bolting on a slick one. besides, a nice one would look out of place, however i will consider one.
I think I have one. I'll look in the shed tomorrow and let you know.
Lee O'Dell0 -
sounds good. if you find one i'm interested in buying it. i'm in no big hurry, since i don't have the that section of the wiring harness done. the pass side does look better with it on though, even if it doesn't work yet.0
I checked and the lense I have for the drivers side is a glass lense. The housings are different for the glass and plastic lenses. Someone else will have the plastic lense you need. However, I do have the passenger side housing with plastic lense. I'm sorry I could not be of help.
Lee O'Dell
no problem, thanks for looking and the effort. the housing i have is fine so maybe someone else has one. thanks again.0
I could use a passenger side lense for my 52. Mine's missing a chunk.0
Plastic or glass? I have the plastic lense in a like new housing. The plastic lense has a vertical crack across the lower horizontal lines. The lense is in a like new housing. Will not seperate. If intereste PM me.
Lee O'Dell0 -
I have a drivers side plastic lense in very good condition
Ron0 -
sounds good, i sent you a private message. if you don't get it let me know. thanks, stacy k0
- 117 Hudson 1916 - 1929
- 22 Upcoming Events
- 98 Essex Super 6
