Getting to the bottom of my gearshifting problem
Old Fogey UK
At last I've found the time to take the transmission out of the '34 Hudson to try to sort out why I can't get it into gear.
I can't find the following information in the Mechanical procedure Manual -
1. How far along the shaft should the thrust bearing assembly be moved by the fork ?
2. How far from the surface of the pressure plate should the clutch fingers be when at rest ? Mine are 37mm, 39mm and 40mm - shouldn't they all be the same distance from the plate ?
Can anyone fill me in, please ?
Calling Dr. Doug ... Dr. Doug wanted in the emergency ward!0
- 103 Hudson 1916 - 1929
- 19 Upcoming Events
- 91 Essex Super 6
- 993 Street Rods
- 172 The Flathead Forum
- 599 Vehicles
