Engine Casting Number
Look at the head markings, the block is the same, only crank and pistons different.
Or check the Stamped serial number on the top Right front corner. if it matches the body the
id is positive.0 -
The quickest way would be to determine if the engine has a single barrel carb or a two barrel carb. 262 = 2 bl & 232 = 1 bl.0
- 120 Hudson 1916 - 1929
- 612 Vehicles
