Carb Identification Help Needed
The carb number should be stamped in the base of each carb0
pacemaker 500 I have a 749S CARB but it is missing the plunger, needle and seat and choke cover, carb is very clean.0
The attached chart is Carter information and will allow anyone to ID the listed HUDSON WA1 Carburetors.0
Thanks, everyone! I knew we could get the answers here.0
As Ed expressed...Thank you
Good Morning Ed,
Found tag on one carb being 2113S
Other one w/o tag following numbers I found on carb: 118-68 – 0-656 & 1-771
Also sent you pictures, sorry if you can't use?
Ray
Bump- added picture of the 749 Flange marking... "682" and "H" . The carburetor pictured is not for sale.0
