How to remove Hollywood rear quarter windows
Hello everyone, I am trying to remove the rear quarter window of a '52 Hollywood but i'm having a hard time. Can someone point me in the right direction?
- the red screws appear hold the regulator rail
- the green bolts seem to attach the assembly to the pillar but i'm not sure
- the blue screws seem to hold the regulator also
Any help in the correct process to remove the window would be appreciated.
Thank you,
Jairo.
Thank you,
Jairo.
its been awhile. but the fasteners you have circled can stay in place.
1st at one end of travel (i think its the up position) the regulator arm will separate from the black bracket running the length of the bottom window edge. at the front corner of the window above your top green circle there is a dull gray cast pivot assembly. remove the two screws holding it to the pillar. then you can wrestle it out. i am thinking roughly the window postion shown in your picture pulling up and into the car.0 -
I THOUGHT THAT THE BAD KID DOWN THE STREET SAID IF YOU PITCH A LARGE STONE AT THEM THEY JUST BREAK OUT JUST KIDDING I'M THINKING WITH NICK JUST AS HE SAID0
