Hydramatic Starter
You probably only need to replace the 'Starter Drive'. Most Local Rebuilders can get a replacement and its fairly easy to replace by driving out a pin behind the spring. 'Worst case' the ring gear may be getting bad teeth....0
Trans & flywheel installed in car about 5K miles ago, and was in good shape then. Will start researching local rebuilders....Ken, let me message you about your core. Thanks guys, Bob0
Yes it's 12V. The starter is supposed to be also, but I'll pull it this next week and give the whole thing a good "once-over"...0
- 117 Hudson 1916 - 1929
- 22 Upcoming Events
- 98 Essex Super 6
- 580 "How To" - Skills, mechanical and other wise
