Auto Enthusiast article installing electric fuel pump on a 51 Hornet
Nice little article on installing a Carter electric fuel pump. Nice to see their project car is a Hornet. Its one of the last articles. So flip forward to it.
http://editions.amospublishing.com/AEW/default.aspx?d=20130816&pagenum=1
Its on pages 42-44, if you can get to the page number selector.
Thanks for posting- I've got an electric pump now, but need to do a better one- It won't build pressure when I turn on the key, have to grind on it just like a mechanical- then it works fine.0 -
Yes is ok. I was just happy to see them feature a Hudson. I got the exact pump they show sitting on my bench just have not installed it yet0
NICE ARTICLE BUT THERE NOT REALY EXPLANING THAT THE NEW PUMP SHOULD BE AT THE REAR OF THE CAR AND THE FILTER IS A MUST JUST BEFORE THE PUMP. I INSTALLED MINE JUST IN FRONT OF THE TANK IT HAS WORKED FINE FOR 10 YEARS NOW WITH OUT ANY TROUBLE AT ALL AND NO VAPOR LOCK NOT EVEN ON A DAY WHEN IT'S OVER 100
I thought they covered that off on page 44 where they discuss best location for installing plus the filter is discussed under the picture0
