Wiper Arms
Is there a way to tighten the tension on wiper arms? Mine leave a spot in the line of vision, so in a good downpour I have to look around the middle. I also use rainex, but when rain is heavy , it isn't enough. Also had wiper motor rebuilt.
Thanks in advance,
Kim
Kim, It may be the tension on the spring in the wiper arm. I'd check to see if it's OK or needs replacing.0
