vacuum pump
essexcoupe3131
HI All,
looking for a all in 1 vacuum pump and alternator to boost my braking vacuum
as the cam is just too lumpy
any info would be great, a nice polished unit would be great if possible, will go into my coupe
thanks
Mike
thanks
Mike
Hi Mike
You still 6 volts?
If you are then I have a 6 volt Vac pump I got x eBay some years ago to try to sort my vac powered windscreen wiper. I've not used it all these years & prob never will, so it's yours if you want it. If I recollect correctly, it previously powered a GM Convertable Hood mechanism.
Dave Y
Hi David,
no run 12 volt system, i do have a Volvo 1 that I have been mucking around with
and I know that Toyota has a diesel alternator that has a built in pump as part of it
was hoping to find something with a bit of bling to go with the rest of the setup
thanks for the offer
what year does the pump come off as I will keep my ears open in case someone is looking for 1
Mike0 -
Some of the 82 Chevy Citations with v-6 had a vacuum booster under the battery. I would think other GM of similar configuration may have them too. Would be 12 volts of course,
Roger0 -
hella makes an electric vacuum pump $150 from Summit: summitracing.com/parts/hla-0094280870
Will check it out
thanks Doc0 -
Why not add a vacuum tank like they used on the 50;s cars with power brakes? A hose with a check valve in it goes from the intake manifold to the tank and another hose from the tank that hooks to the vacuum fitting on the booster unit.0
Thanks Marconi, will throw that into the mix
and see where I go
Mike0
