Changed the head gasket and now it won't crank
JasonNC
edited October 2013 in HUDSON
Now all it does is spew gas out of the carburetor. My guess is that I must have put the gasket on upside down since I can't think of any reason why the carburetor would start acting up when it was working fine a week ago before I took the head off. Before I take it back off, has anyone had this happen?
  • sounds like your carburetor float is stuck I think I'd tap on the inlet line little bit and see what happens
  • I tried that and nothing happened. I may have my mechanic take a look at it in the morning before I take that head back off.
  • FYI
    Even If the H/gasket was inverted the motor should still crank. Make sure the carb flooding didnt fill the cylinders by removing the S/Plugs then look for other reasons....
  • I concur with Ol Racer....at $60.00 a pop for head gasket, I would find the fault of the gas issue and not remove the head.....Nine out of ten times these kind of issues are some thing simple?
  • Gas spewing out of the carb? Won't crank..Sounds like you're distributor/wires are off.
    Did you pull the distributor? re-check your wire routing from #1 TDC.
  • Maybe you should clarify some here . When you say it "Won't Crank " do you mean it turns over but wont start just leaks gas ?
    My thinking is the fuel pump wont work if the engine is not spinning. So unless you have an electric fuel pump I dont see how putting the head on is connected .
  • More information please. "Won't crank" - does this mean you cannot turn the engine over?
  • Maybe this will help. Does the starter spin the engine?
  • Starter spins the engine and spark is going to the plugs. I didn't mark the distributor cap and put the spark plug wire for #1 back on by memory. I have tried to reset timing but haven't been successful. Will be out of town for two days, so working on it will have to wait.
  • Sounds like your firing order is off . Make sure #1 is in the right place on the cap. Just pull the cap and make sure the rotor is pointed to #1. Then 1-5-3-6-2-4 I bet she fires. Good luck .
  • Ol racer
    edited October 2013
    Just to add another suggestion to First remove the #1 Sparkplug then put your Thumb tight on the hole then 'bump' the starter until your Thumb pops off the hole and look where the Rotor points, and that will be #1, then follow the Firing Order with your Wires....
  • Jason - its real easy to get #1 plug in the wrong place - chances are you're only off by 1 slot, but agree with ol racer - make sure you're TDC #1 then route your lines. If the rotor looks like its between posts on the cap #1 should be the previous post in the distributor rotation. (assuming Hudson timing is set to BTDC, if its ATDC it would be the next post in the rotation)
  • When you feel your thumb start to rise, then look at the flywheel and turn till you see the long mark at the motor plate pointer, rotor should be on #1, then install the wire and go to 5-3-6-2-4 clockwise. Walt.
  • Okay, my memory was 180 degrees off from what it should have been. It finally cranked but the timing is way off. I'll have her right by Tuesday.
