Clips Available
Are the clips available for the 52 hornets triangle bottom trim for the sedan. There is two strips running from wheel to wheel Iam missing one whole side. But I have one looks like a press in clip for the top triangle. Any Help app. Thanks John
Dellis Hudson Makes them. You can find his contact information in the WTN classifieds. He makes the to order.0
You have an earlier rocker (48 thru 50), for the upper molding you must remove the rocker and use "T" clips you cut to size and slide into the stainless then bolt with washers to the back of the rocker, then re-install the rocker, the bottom retainers can be gotten from Dellis and need to be riveted or screwed on since they are galvanized0
Thanks You guys, Now it makes sense John0
- 120 Hudson 1916 - 1929
- 612 Vehicles
