U.S. CAR PARTS INTERCHANGE MANUAL 1937-1948
There were no Part Numbers. Just what parts interchange between 1937-48 U.S. made cars.
Lower Contol Arm Inner Shaft Kits:
Hudson 1940-47
Frazer 1947-48
Kaiser 1947-48
Oldsmobile 1939-48
Lower control arm pivot pin kits
Hudson 1940-48
Chrysler 1940-48 Six
Dodge 1939 (Late); 1940-48
Fazer 1947-48
Kaiser 1947-48
LaFayette 1940
Nash 1940-48
Plymouth 1939 (Late); 1940-48
Upper control arm inner shaft kits
Hudson 1940-42 Same
Hudson 1946-48 Same
Upper control arm pivot pin kits
Hudson 1940-42 Same
Hudson 1946-47 Same
Tie rod ends
Hudson 63,73 and Terraplane 1936-37 Same
Hudson 1936-48 (except 63,73) Same
Steering knuckle thrust bearings
Hudson 1936-37 Same
Hudson 1938-48 Same
Will add more information from the manual later.
Hope this will be useful.
Lee O'Dell
Hudson 1940-47
Frazer 1947-48
Kaiser 1947-48
Oldsmobile 1939-48
Hudson 1940-48
Fazer 1947-48
Kaiser 1947-48
LaFayette 1940
Nash 1940-48
Hudson 1940-42 Same
Hudson 1946-48 Same
Hudson 1940-42 Same
Hudson 1946-47 Same
Tie rod ends
Hudson 1936-37 Same
Hudson 1938-48 Same
Lee O'Dell
IMHO most of these general interchange manuals, like Motors, Chilton and Hollanders, are practically useless when it comes to finding parts for Hudson. It's not that there aren't interchangeable parts - it's just that the compiler of these manuals didn't dig deep enough. Which is understandable. I had an early Hollanders but decided against scanning it for the online library - over 600 pages for one thing and the return would be minimal.
There are many parts that interchange between Hudson and other independent car makers for example.
However, that said, there is some value in this info. Hudson part numbers can be found in the parts books I have in the online library.
Alex Burr
Memphis, TN0
