Step Down Lube Chart
Roger Harmon
edited January 2014 in HUDSON
Does anyone have a .PDF of the fold-out lube chart from a (later) step down owner's manual they can share up here?
  • http://hetclub.org/burr/manuals/1952_Hudson_Service_Manual.pdf
    have you tried printing it from here figure 1. its printable
    steve
  • Yeah; that's the same one in the service manual. It dosen't enlarge very well. I Was hoping to make a poster-sized one.
  • Try to find an owner's manual for your year, they have a nice folded glossy chart.
  • See if the local Kinkos/Fed Ex Office etc.... can convert the PDF page to a VECTOR image, then it will enlarge.
  • Glowplug
    edited January 2014
    If you want to poster size a smaller image, get one of the shareware or cheap to buy POSTERI Making software programs. TU COWS etc downloads. I bought some off the wall program years ago when compute power was nothing and a buck or two for something to do a one time job was okay. I still use that program, it cuts the image into pieces and allows you to print overlapping standard sheets which have assembly and cut marks printed on each sheet. I make up the poster at home on my PC then put it on a thumb drive and take it to FeDX Kinkos. The thumb drive plugs into the printer, push in the credit card and print away. Then you can use their glue, tape and professional cutter to assemble the poster. If you want then you can have the whole thing laminated in some plastic ... made lots of Hudson stuff that way... easy to scan and blow up Hudson Ads etc.
    BTW, Fed X wants to see your permission for any image or publication... lots of monkeying around. I do the scanning and prep before arrival then no need to answer those annoying questions.
